It is currently Fri Aug 08, 2025 12:27 pm
PostPosted: Sat Jul 11, 2009 8:31 pm
So, I know Tacoma does it. I've spotted one or two pictures of guitars from other builders also. My latest guitar has a neck built like Colin S. has showed us. As I was building it I kept thinking of the Tacoma neck joint and how easy it would be to set the neck angle.
So, anyone here using this style neck?
What are the drawbacks to this system?
PostPosted: Sun Jul 12, 2009 3:54 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
Tacoma only uses that style neck on their "Wing" series. (or at least they used to before FMIC killed Tacoma). The bracing is quite different on them, with alot of attention paid to keeping the neck block from rotating. The neck/body join is at the 15th fret. You can see the bracing on the second page of this catalog.
http://www.tacomaguitars.com/resources/pdf/tacoma05Catalog.pdf
To my ears those guitars sound similar to a ladder braced guitar.
PostPosted: Sun Jul 12, 2009 7:51 pm
Last Name: Shaw
City: Philadelphia
I would think the drawbacks are the need for a much larger neck block. I would think it might impede on the tops vibration some what because of the larger block to top glue area. I don't see it offering and increased playability either. And last but least i just don't think it looks good...Mike
PostPosted: Sun Jul 12, 2009 8:41 pm
Chris V has the right idea. Is that David Myka's? I used a neck block like that on my latest. That is similar to what Colin S uses. I'd link to his post if I knew how. I was thinking an adjustable neck, I'm already using an all hardware joint and a fully supported fretboard.
Mike, I'm with you on the looks. Playability would improve in one aspect if it was an adjustable neck as opposed to the set neck. How much extra vibration can be impeded that is'nt already being taken up by the A braces, UTB and the fingerboard?
PostPosted: Sun Jul 12, 2009 8:54 pm
Not sure how they are braced, but the Taylor Big Baby uses a similar neck without a traditional heel, For the money they play/sound very nice.
PostPosted: Sun Jul 12, 2009 9:45 pm
Last Name: Shaw
City: Philadelphia
Yes this does remind me of the bolt on neck fender acoustics that had used a fender style neck plate and extra long neck screws. Did they also make a glued in neck similar to this? I don't remember them...Mike
PostPosted: Sun Jul 12, 2009 10:21 pm
Spooky, I was just thinking about this today, if it was possible and had ever been done. My question is answered. Not sure if I like the look of them.
PostPosted: Mon Jul 13, 2009 1:56 am
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Small world indeed!
OK, here goes.....
I've been stealthily working on a version of this idea for almost the past year! I'm almost ready to show my final prototype - I should have a nice playable MJ guitar built with it by the Guitar Festival in August - I'll bring it along with me for show/tell although I don't have a booth. Like others before me, I use carbon fiber tubes to transfer the string tension from the neck plate into the sides of the guitar at the waist and provide anti-twist properties to the neck plate. My neck plate is thin/small compared to traditional neck blocks. There is no external heel at all. Also, since my neck/fretboard floats over the soundboard, the upper bout now adds significantly to the sound of the guitar. The neck is "bolt-in" using two 1/4"-20 allen cap screws. The neck angle can fairly easily be changed to suit any player's desires. The design uses much less wood than a traditional mortice/tennon or dovetail neck joint, hence is much lighter. It's also easier/faster to make and less expensive on materials. My early prototypes sounded pretty good. Here's a few photos of the CF tubes and neck block during glue up. I'll post some more photos and perhaps a sound clip in a week or two. 8-)
You can click on the photos to see/download the hi-res versions of them.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Mon Jul 13, 2009 10:05 am
Nice start to a guitar there Dave. I've used the small neck block with buttress rods in previous builds. I've been happy with the results. The two holes in your neck block have "bolts into the heel" written all over them. I look forward to seeing more pics when you can post them.
PostPosted: Mon Jul 13, 2009 4:37 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Steve Klien has been making guitars this way for years !
Check out his site & get his DVD if still available.
Mike Collins
PostPosted: Mon Jul 13, 2009 7:24 pm
Thanks for the info Mike. Not the best views on those pics on his website but I should be able to find more with some searching. Mr. Klein is putting out some very interesting work there. Quite the customer list also.
PostPosted: Mon Jul 13, 2009 7:25 pm
Last Name: Fifield
City: San Jose
Mike - I took a look at Steve Klein's website but I can't see much evidence that he uses a heel-less neck - am I looking in the right place? In a couple of the photos, I could maybe convince myself that there's some neck shape change (to rectangular) just before it enters the body, but none of the pictures that I could find are clear on this. The couple of pictures showing the inside bracing show a fairly substantial neck block inside the instrument - nothing like I'm doing. I'm still fairly sure that my design (which you haven't seen yet) is "new".......we'll see..... :geek:
Steven - if you look closely at the two holes, you'll see they actually have 1/4"-20 threaded T-nuts installed in them. There are no holes in the outer shell of the guitar 8-) Eat Drink
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Mon Jul 13, 2009 8:51 pm
I see the inserts now Dave. Can't wait to see what you've got going there. I did some drawing on my new neck attachment design. It will be on my next box unless the pending commision comes through.
PostPosted: Tue Jul 14, 2009 6:35 pm
Here is another way to do it. This is a German builder, Gottschall.
Users browsing this forum: Darrel Friesen, J De Rocher and 36 guests
